Herb 64
- Nashville, Tn
- 2015 golf
Looks like the oil pan is leaking at the gasket. Is this usually the gasket or the plastic oil pan? Also, not sure if the sensor is leaking or not. Can i replace it later without removing the oil pan? I checked higher up, including the fill cap and no leaks running down to the bottom. 2015 with 65K.
