rebound is controlled. compression is not.I haven’t heard anything but good things about the Ohlins.
What is controlled on the B16’s if not compression or rebound damping?
I’ve been running the MSS Sport springs with my DCC with zero problems. They track well and are adjustable - albeit a pain in the butt. They handle stage 3 power with no problems. Are they the best? No, that’s reserved for KW and Ohlins.I'm learning that lowering a car with DCC is a PITA. There aren't many options to keep the electronic dampers, and of those options I'm reading lots of bad things.
Bilstein Damptronic B16 - Overly stiff and apparently easy to end up riding on the front bump stops?
KW DDC - Finding many that have had issues with spring binding. Revised springs since launch. Can anyone verify this? Has anyone had any luck with this kit?
KW V1 - V3 - Worth it? Any good? I'm seeing mixed reviews.
I'm nervous to delete my DCC. For those that have done it, did you regret it?
So like too soft on compression? How low were you?
Glad you’re happy with the Bilsteins. It’s all a bit of a gamble of unknowns to find something that works for you. I’ll need to stick with B6 Damptronics/stock ride height.
Very well articulated.Yes, compression was too soft. It was like having stock compression but with a lowered car. My fenders were touching the tire on bigger bumps. Thankfully I didn't do any damage up front other than wear spots on my fender liners. I would have been better off with something that was compression adjustable.
The Damptronics feel tighter. They are stiff, but that's not how I would describe them. The damper quality is evident, even over large bumps. Very smooth, tight, responsive. No bottoming out or riding on bump stops either, as some have reported. I'm assuming people just don't know how to set them up properly. There is a specific height range that the perch must fall within. 235 to 245mm from the center of the bottom pinch bolt. The front springs also have a specific orientation.
There are plenty of extra threads to go lower if I wanted to, but that's when you start running into those issues I mentioned. The kit lowers the car 1.5" overall, then you get the additional 10mm to play with. I'm sitting at a little less than a one finger gap with the fronts at the 235mm height. Like I said, I'll prob write up a complete review and start a new thread referencing both this one and the others related to this. I'll also post up a spreadsheet of all the replacement hardware with parts numbers and torque specs.
So how are you doing with these? I am considering the B16DCC's over the B6DCC/stock springs now because of availability.Yes, compression was too soft. It was like having stock compression but with a lowered car. My fenders were touching the tire on bigger bumps. Thankfully, I didn't do any damage up front other than wear spots on my fender liners. I would have been better off with something that was compression adjustable.
