Ohlawd
- El Paso, TX
Used JB4 with Bluetooth module
Also wired in for meth. Comes with FSB, Solenoid, Pump and Devils own tank tap for washer bottle. Everything is completely plug and play. I installed the meth kit using Delphi connectors and insulating all the wiring.
I will include the bracket I fabricated to mount the pump to the bumper beam, the bracket to mount the solenoid to the block, the fuse tap to power it and all you need to do is plug it all in. I will help walk you through where I mounted everything as well. Unless you want to do it all on your own.
I am debating separating the methanol and using the parts on another setup. For now it’s sold as a whole kit.
$600 shipped anywhere in the 48.
