Home work is insane rn. I was going to get my screened in patio fully closed in. No flooring, no roofing, ductless ac, just two walls and 2 windows and a door. $56,000. I literally said there's a used rs3 at Audi Jax for that price. That will make me waaaaaaaaay happier goodbye.Any of you guys want to help me lay pavers in my backyard? Just got several quotes ranging from 5k to 8k. Craziness......
Exactly. I got 4 different quotes they were all in the same range.That sounds like the "I don't really want to do this project" price!
I did, but it's not high on the priority list right now. Plus it wouldn't really add much value to the house.You ever thought about doing it yourself? Sounds pretty straight forward.
They are same diameter and offset. Do you know rotor width? Mk6 R are 30 mm.I have a question for @GTIfan99 I was looking at the racingline stage 2 brake kit... Looks like they use 345 mm rotors. Are those the mk6 r rotors?
There is a bushing and a bearing. Replace both. And while you're doing that, but the Eurosport camber kit. You'll end up with between -1.5 and -2 camber with no added nvh. Well worth it.Hate to ask, but earlier I mentioned I was recommended to change my bushings when doing my springs. Devin mentioned mounts. Looking online it looks like these terms are interchangeable. Are bushings/mounts the same thing?
If someone has time or doesn’t mind, can someone shoot a link to a kit that includes all the pieces I should swap out? If too difficult, no worries. Gracias
** Just spoke to Anthony at O’Steen while I was typing this and he advised me to get Powerflex purple strut top bushings and bearings. He said uspmotorsports and ecstuning should carry them but I don’t see them listed.
Anyone care to point me in the right direction?
Don't know, bleeder is defective. He ended up using mine and it worked fine.Dang how's that happen? Excuse my ignorance but what's the obd11 needed for? Can't he just refill the system and bleed it until all the air is gone? Or is there some sort of calibration necessary?
Yeah dude I’m open to that. Just message me this weekend and let me know what’s what.@mrmattolsen I might have broken my car. If I can't get it sorted before Sunday, can I co drive with you? We'll throw my tires on your car.
The site says 345x30mm. I just want to make sure that if I buy this kit I can actually replace the rotors. LolThey are same diameter and offset. Do you know rotor width? Mk6 R are 30 mm.
That's exactly it.The site says 345x30mm. I just want to make sure that if I buy this kit I can actually replace the rotors. Lol
