Scissor jacks and the widow maker are intended for limited use in very specific arrangement; perpendicular to flat higher grip hard surface. They are not service tools at all. Your user manual only calls on them to be used for changing our a single tire, with the other three inflated tires on the ground. The remainder of your tool kit is there to facilitate the changing of a flat tire, nothing more.
The jacks are lightweight, cheap in construction, and prone to failure. The screw shaft, threaded collar, pivots, stamped cheap metal, etc are all failure points. This is why they should be considered for only emergency use when you have nothing else on the side of the road... and then only in optimal conditions. Your car only has one because pretty much every agency covering vehicles in the world requires the vehicle to be equipped with a spare or alternative to a spare. If they could get by with it, manufacturers wouldn’t give you even that.
I’ve used all manner of jacks, including a scissor jack for track day tire swaps when I was younger. I’ve had two fail. One was the screw mauled the threads and jammed up the thing, the other was a lateral failure that crushed it like a beer can. My hate for emergency use type jacks runs deep, to the point that I had to open my boot to figure out what type I have.
Your life, your decisions, but fuck those things.
an aside: I see
@anotero chimed in,
I’m sure it was something very helpful to the conversation.
