gokujou1
- Minneapolis
So I have been following this thread for a long time and wanted to add my experience to hopefully help others that find it.
Current Issue:
The 2018 started making this noise about 9 months in. To avoid the shop I just started trying to fix it myself as I love the car. I backed the sunroof off a little to avoid rubbing and this worked for a few months, but then it got real cold (about -20 F) and the sound came back worse. Then I found this thread from a video.
My Fix Attempts:
I first tried using the female side of velcro as I saw in a couple videos, but this didn't stop the noise. I placed a couple pieces on each edge and in the middle of the channel Techno Duck points out. Cleaning the rubber piece on the glass that sits in this did seem to temporarily help a little so my best guess was I wasn't preventing enough contact.
Second try I used the felt Techno Duck mentioned. Placing 7-8 inch swatches on each side the covered the full channel the rubber rests in (from the front edge of the plastic piece to the back lip of the channel, making sure to get a flush fit to the plastic). This also didn't fully stop the noise, but it did reduce it a lot. Thus I just applied felt to the full channel the same way to see, and so far I have been squeak/creak free for a couple weeks. I just get a tiny noise if there is a lot of body twist, but I have a couple small gaps in the the felt I assume the big twists sometimes let make contact.
I also use Gummi Pfledge to keep the visible rubber conditioned.
Backstory:
I had a 2017 Autobahn and it creaked like none other with body twist after half a year or so.
I took it to the dealer a number of times to have all the TSB work done for it. They were never really able to fix it. Fast forward another 6 months, I was out of my car for roughly 4-5 of them in loaners while they tried things. The local dealer's shop also broke like 15 other things doing so. VW corporate stepped up and made things right though and replaced my car with a 2018.
Current Issue:
My Fix Attempts:
