Help With Removing Front Window Channel
dishwab
Detroit MI
Hey all, hoping to get some pointers and/or video instructions on how to remove and replace part 5GM-837-432-G-5AP (window channel) from my 2019 Alltrack. This is the black rubber/felt gasket wraps the front window on either door (see diagram below, #2).
Somehow, the people doing my tint install managed to slice a chunk of it off on one side of the car, so I'm going to ask them to pay for the part and I will install myself. They damaged the vertical part that runs between the main door window glass and the small triangle glass.
Looking at the parts diagram here, I assume I'll have to remove the inner door panel and maybe the window glass as well? Not sure what else though... side mirror? Any other interior bits? Any help would be appreciated...
Thanks
777-300ER
St Joesph Mi
As far as I know, roll the window down and pull it out in the middle. Pry it out around the a pillar and then slide it up and out of the door. Shouldn't need to remove anything at all.
