Chris43
- Bury, Lancs
I have exactly this problem. I am completely familiar with the EPB and like the system. Unfortunately, and also intermittently, when I drive off from a parked position on a hill, the handbrake doesn't hold and the car will roll back (or forward). I am seriously concerned that this fault will cause an accident and yet neither my local dealership or VW are able to come up with any solution. I feel I have an unsafe car...
This happened to me a few times when I first had the car. I put it down to my technique with the accelerator / clutch bite point. I admit its a bit alarming when it first happens
My experience is that if you are a bit slow bringing the clutch up and don't have enough RPM the car disengages the autohold before the clutch has enough grip to take up the drive, thus causing the car to roll.
I'm sorry if I'm teaching you to suck eggs but If I've a steep hill start my technique is to give it about 2000rpm then let the clutch up at a fairly rapid rate. With a manual handbrake you can feather the clutch and accelerator together till you feel the bite, this isn't possible with the EPB, you need to move the pedals differently. If this doesn't work you may well have a problem with the car.
Have you tried going somewhere quiet so you can do a few hill starts and get the feel of the system?
