Anthony3o55
- South FL
whats up guys. Here’s a back story. Manual GTI, got the car with 12k miles last year. Currently at 36k now. I learned manual on this car so I’ve stalled the car a couple times in the very beginning. I got no tune, just a DP. I drive spiritedly occasionally. I dont experience any slip at all. If I floor it on any gear no slip. Rarely clutch would slip quickly when shifting into a gear like 2-3 or 3-4.
At 30k miles I’ve been getting a strange noise on the clutch if I dont give enough gas. Its literally from releasing the clutch almost half way and then giving it gas. For example, Im at a light and it turns green I’ll release the clutch bad and give it gas under 1k rpms. (I dont do this often but it happens by mistake) Doesn’t sound good at all. Its a screeching/grinding noise. Its hard to tell exactly where it’s coming from but I’m guessing under the dash and sometimes under the shifter in a way. Has been happening more frequently now. I am assuming it is the clutch but could it worse? I still got warranty. My next mod is a new clutch with a DMF flywheel. But before I install that clutch I wanna make sure its just the clutch and nothing else I should worry about. Thrust bearing bad, crank walk, I have no idea. I never owned a manual, I ride the car by myself most of the time so I dont know what type of noise it could be. Anything helps, thanks
