Hello guys,
I have VW Golf 7 2.0tdi with bi-xenon headlights and auto function on my lever.
I want to know, is there any option, when the car is running on sunny day and my DRL's are ON, rear lights are ON too, but i want to be only from DRL's ON ?
When its sunny day DRL's front/rear and interior lights are ON. I want on sunny day DRL's to be ON only on front and when the night come, to switch the lights in interior, back lights and headlights ON.
Is there any codding for this ? I already have VCDS.
Also, CH/LH function doesn't work on me.. I don't know the codding in my centr.elect 9. Can someone help me with tips and codes to do it ?
Thank you.
Thank you.
Code:
unday,27,June,2021,07:13:28:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WVWZZZAUZFP556075 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZFP556075 Mileage: 240930km-149706miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 7545
Revision: 83H22---
Coding: 111D0032032405082000
Shop #: WSC 00028 028 00204
ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AFB47EFFDDF505645-802E
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 041 P HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4507
Revision: 05853104 Serial number: TFK01409151803
Coding: 0014
Shop #: WSC 00028 028 00209
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 2541449324E10FAE58-8070
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 62724000000723
Coding: 04FA62A1242509720377060741C82920462490C0608294F30062507AC202
Shop #: WSC 00028 028 00248
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033.rod
VCID: 4581E413C4A1EFAE78-8010
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 AF HW: 5G0 907 044 AF
Component: Climatronic H03 0912
Revision: 00001K08
Coding: 02020104202100011005004000101000
Shop #: WSC 00028 028 00067
ASAM Dataset: EV_ACClimaBHBVW37X 003018
ROD: EV_ACClimaBHBVW37X_003_VW37.rod
VCID: 6BD572AB8285F9DECE-803E
Fresh Air Blower Front:
Geber für Kältemitteldruck/Kältemitteltemperatur:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AA HW: 5Q0 937 086 AA
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86580410140583
Coding: 00001A42C24102FB4BE44000000C07081000000000000000000000000000
Shop #: WSC 00078 790 12345
ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
ROD: EV_BCMBOSCH_013.rod
VCID: 79F958E3F8D95B4E4C-802C
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140905 043 0551
Serial number: 140920203128
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y14M10D10H15M24S43
Coding: 00A8DD
Relative Air Humidity Interior Sender:
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 F HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0047
Revision: -------- Serial number: 39431427100099
Coding: 0031061051
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 428BFF0FD58FD8965D-8016
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R0BNNP4
Coding: 98CCC000000000005C0000CF004800000065
Shop #: WSC 00028 028 00057
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4189F003D089C38E44-8014
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 003 009 14
Component: SideSensor_Df 001 0887
Serial number: 3576700000080D44F01U
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 002 609 14
Component: SideSensor_Pf 001 0887
Serial number: 35867000000D2261111D
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 402 309 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502BF176A6B4B06O
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 402 409 14
Component: SideSensor_Pr 001 6149
Serial number: 3526502B3175A90393A8
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 401 909 14
Component: FrontSensor_D 001 6149
Serial number: 3556502BD176A6B4A17R
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20140926400075
Coding: 0410
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F8DF6FBA67DB57E32-806A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 741 HW: 5G1 920 741
Component: KOMBI 204 4270
Coding: 07A511082B90000800086A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009037
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 64C719976F5BB6A68F-8030
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 02101410800859
Coding: 030100040B087300EF00024A1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0038
Serial number: 27140002390380024391
Coding: 28FFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 6711464603
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 C HW: 5Q4 959 593 B
Component: TSG FS 009 0015
Serial number: 0000119708121
Coding: 003B0320D000020000001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000006743261
Coding: 010000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 0303
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 C HW: 5Q4 959 592 B
Component: TSG BFS 009 0015
Serial number: 0000119616374
Coding: 003B0120DE00020000801000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 4487F917CF9BD6A66F-8010
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000006686744
Coding: 090000
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 069800000B000200
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
VCID: 408FF507DB83CA864B-8014
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 846 A HW: 5G0 035 846 A
Component: MU-S-N-ER 041 0430
Serial number: V1F02809140617
Coding: 02730201FF00000011110001000800001F0100840100010045
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 275D4E9B5EED1DBE6A-8072
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9PS4041SQ
Data medium:
Subsystem 2 - Part No SW: 5G0 919 866 BD HW: -----------
Component: ECE 2020/21 --- 0094
Serial number: --------------------
