Hello, i have some problems with my actuator, i got Golf 7 1.8 IS12 running on Stage 1, 122000km on a dash, 1 year ago my car threw me EPC light with P2563 - Implausible signal, i made initial adaptation and i dont get EPC light anymore, but my turbo is underboosting, so i think maybe problem is in my wastegate.
During my initial scan, I obtained the following voltage values:
Initial adaptation succeed. Then i tried to make Position check of end stops of charge-air pressure actuator and it failed, aborted-safety reasons.
Here are the updated voltage readings I recorded after position check of end stops:
I made position check of end stops again and it still fails, but initial adaptation does not fail.
WG is not stuck, during the tests i can see and hear it moving, but for some reason with ignition off i can't move it by hand.
Here is some log file, you need ot check 0.356 and 0.354, this shows actual boost and specified, i will try to make better log later: https://datazap.me/u/martmak/log-1693302300?log=0&data=1-3
I will be happy to extend my WG lifespan for other 4-6 months, because winter is coming and changing IS12 to IS20 (used one) is kinda useless before winter.
At this point, I'm seeking guidance on the appropriate voltage ranges I should be aiming for in order to ensure the proper functioning of the wastegate and the overall actuator system.
