Go Fast Bits DVX BOV/Diverter Dual Outlet Valve
Aristocrat Autosport
GOLFMK7 Official Sponsor
Buena Park, CA
GFB DV+ Diverter valve (Part number T9301) is a direct bolt on factory valve replacement.
Designed to replace the weak plastic Bosch diverter valves commonly found on European applications like Audi, Ford and VW, but with the GFB TMS advantage.
These unique products are manufactured in Australia in accordance with ISO 9001 which ensures our products meet stringent quality requirements at all stages of manufacture. Unlike other aftermarket Bosch replacement valves on the market, the DV+ will hold as much boost as you can throw at it WITHOUT the need to adjust the spring pre-load or purchase different springs.
Unlike other aftermarket Bosch replacements on the market, the DV+ will hold as much boost as you can throw at it WITHOUT the need to adjust the spring pre-load or purchase different springs. This is due to the pressure-balancing design of the DV+ which means that under WOT conditions there is equal boost pressure on both sides of the piston, so it will stay shut under boost REGARDLESS of the spring setting or the boost pressure.
PM if interested in any of these products!
Facebook: https://www.facebook.com/AristocratAutosport/
Instagram: https://www.instagram.com/aristocrat_autosport/
Website: www.AristocratAutosport.com
CALL OR TEXT: 714-340-6596
Email: Sales@AristocratAutosport.com
