TimmyTbonez235
- New jersey
- 2018 GTI SE
So a couple months ago I installed my DIY MPI kit but at the time I didn’t have the fuse box terminal connector to run a clean install so I just used a fuse tap for the time being. All was fine and running smoothly. Today I go and disconnect the battery, pull the fuse tap, and reinsert it. The car starts and dies shortly after. I have already ruled out the chances of it being a fuse, the fuse tap and the fuse relay. Low pressure pump is also not priming fully, it’s starts to prime when I open the door then it stops before it finishes fully priming. For reference, I was tapped into the fuel pump control fuse when I initially had installed the MPI. Kinda stumped as to what it could be. Any help would be greatly appreciated.
