I didnt do it but there is definately a trick to get it pop out. Here is pic of how it looks along with what i replaced it with. I think the mechanic told me he had to get those little black tabs compressed some how before it would pop off. I think he might have used like a little hook/pick or something.
Sent from my SM-G935V using Tapatalk
Does replacing this check valve cause long cranks or issues? I’m getting fuel cuts on full WOT on my tune and my tuner wants me to check LPFP readings but I think this could be the restrictionI didnt do it but there is definately a trick to get it pop out. Here is pic of how it looks along with what i replaced it with. I think the mechanic told me he had to get those little black tabs compressed some how before it would pop off. I think he might have used like a little hook/pick or something.
No I don’t have mpi. And I know u can’t read lpfp psi. I’m going to have to add a fuel pump gauge between the hpfp and check valve. I was just seeing if he had symptoms of a bad check valve to see if I need itDo you have MPI? You can't read LPFP pressure without MPI.
Have any logs of your pulls where your car cuts out?No I don’t have mpi. And I know u can’t read lpfp psi. I’m going to have to add a fuel pump gauge between the hpfp and check valve. I was just seeing if he had symptoms of a bad check valve to see if I need it
Yeah I’ve sent a couple logs to Stratifed and he emailed me back showing me where it dropsHave any logs of your pulls where your car cuts out?
That's your high pressure fuel rail reading. Can you post the log csv? Datazap? Any ethanol in the tank?Yeah I’ve sent a couple logs to Stratifed and he emailed me back showing me where it drops
https://datazap.me/u/dylanmk7/data-5-cobb-is38-tune-data-4-stratified-is38?log=1&data=6-9&zoom=0-664That's your high pressure fuel rail reading. Can you post the log csv? Datazap? Any ethanol in the tank?
