FS: Gas Pedal Spacers for Trail Braking and Heel-Toe
etrips
Virginia
Golfffff Rrrrrr
PM Sent!
silkblue
Got mine! Clean - and easy install. Gas pedal is noticeably higher and still feels stable. Can't beat the price.
MiamiBourne
South Florida
2016 6MT Golf R Oryx
Hey folks,
Ended up with a bunch of extras when I needed just one. Hole alignment of the original was corrected thus no dremelling is needed to fit this version. Made out of high strength virgin ABS+ with high infill for extra durability. Drop in and play! This pivots the gas pedal up a smidge which allows for better/smoother transition when heel-toeing since the stock gas pedal is fairly recessed below the brake pedal. This also helps for trail braking since my legs now flex similarly (before my left leg would sit almost an inch higher to allow further extension in my right leg for the gas).
Looking at $20USD shipped within Canada and the US! Colour is white.
Install procedures (with pictures): https://bit.ly/2GWtuNj
You made these? Ever think of making a pedal extension similar to Rennline's for the OEM gas pedal?
https://www.ecstuning.com/b-rennlin...ImiYhxbONHCwxwvSW0dauTG-w1UKUoZRoC1WoQAvD_BwE
I'd like to get one made. I'm even thinking of buying a spare pedal (the entire assembly) and having someone make it.
civicdrivr
Virginia
[pic]
An extension would definitely be cheaper, but I'm running these with the WCT spacer, if you're looking for something already on the market:
https://www.srpracing.com/pd-golf-and-gti-2015-mk7.cfm
Pedal placement took some getting used to, but it works very well.
VTECaddict
Seattle, WA
Got mine and installed it today. I have DSG but I still hated the pedal placement with the large differential between the gas and brake. Feels much more natural now!
daisoma
x2
I can actually heel toe, not very good but at least I can practice now.
