This is not possible. The SWaP codes are different.Dealer can remove though For a cost. I just don’t know if the new sensor is compatible with the existing modules.
I've yet to see anyone actually prove they can add the SWaP codes. I've seen people say they can, but it's never been proven.Remote coders can help with the SWaP codes, I wouldn't consider that a deal breaker.
However I feel the modifications to the car is the harder part. To use the upper grill from the MK7.5 where the radar sits, you would need to replace the front fenders, bumper, and headlights.
I had it done to my car. MRR radar part # 5Q0907561G. Purchased it used from ebay, it had component protection and required a SWaP code added to my VIN in order to work.I've yet to see anyone actually prove they can add the SWaP codes. I've seen people say they can, but it's never been proven.
My car did not have ACC from the factory, but the retrofit works perfectly. Forum member @doctor did the coding remotely.
Actually i checked last weekend both grills, mk7 and 7.5, i didn't try but it seems two intertwined pieces. So i mean it can be seperable and fit 7.5 grill, so if it works, you can fit, The inside of the grill is 7.5 and the outside is 7.Anyone know if this is possible? I already have the ACC sensor in the front grill. I’d like to piss that off and have the one in the emblem instead.
This would be great if it works, are you saying to remove the logo from the 7.5 grill and install it in the grill from MK7?Actually i checked last weekend both grills, mk7 and 7.5, i didn't try but it seems two intertwined pieces. So i mean it can be seperable and fit 7.5 grill, so if it works, you can fit, The inside of the grill is 7.5 and the outside is 7.
Yes this is what I was thinking too. The badge looks the same. So I assume you would need.Actually i checked last weekend both grills, mk7 and 7.5, i didn't try but it seems two intertwined pieces. So i mean it can be seperable and fit 7.5 grill, so if it works, you can fit, The inside of the grill is 7.5 and the outside is 7.
Acc connectors are same just grill inside is different behind the badge, i mean if the change inside of the grills it will solve i thinkYes this is what I was thinking too. The badge looks the same. So I assume you would need.
badge/sensor
Wiring harness. (Assuming they’re are different)
