Fault: Lighting Error - Help please !
sjpsound
Weston Rhyn
Mk7 2.0 se
Hi, my 2013 2.0 tdi bluemotion Golf is showing "Fault: Lighting Error" all the time
I've checked all the bulbs and all are working fine...any ideas ?
Thanks !
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Could be one of the control modules bolted to the underside of the headlights...Without a OBDII or VCDS fault code scan we won't know.
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
StorableComa
SoCal, USA
17 GSW S FWD
Ah, yes - that's what I thought....any recommendations of one to get ?
Depends on what you'll plan to use it for and price point. Cheapest would be ODBEleven, if you want more features but a higher price point the Rosstech cables are good. I picked up a Hexnet V2 through their exchange for my old Can+USB model since that doesn't work on some MK7s and newer.
https://store.ross-tech.com/shop/cat/VCDS/
https://obdeleven.com/en/products-page
I'd double check on ODBEleven, should work as it works on all NAR Golf models.
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
As above....I got my Ross-tech cable via Gendan in the UK
