Arac
- British Columbia
Went to the track last night and thought I'd report my results. First thing to say is the track was very, very slick. They scrapped the burnout box and were using a new watering system. I found that it was so slick that I'd get massive axle hop and power cutting unless I did a launch before lining up. Wasn't too pleased but whatever. The track was aware of the problem and hopefully they will have it sorted out soon. Eurodyne does feel stronger than Unitronic, both with 91 tune, but that makes sense as the Unitronic tune is advertised as a bit milder. Car has no other modifications and is DSG. Altitude is 2200'
So here is my best time, which is .501 and 3mph better than stock. I should be able to cut at the very least .050 off my 60' time and I think I should run well into 12.6s or maybe even 12.5s with good launch conditions. I should post that, for comparative purposes, the official NHRA correction factor gives 12.566 @ 107.64 mph.
For comparison here are some pure stock times at the same track, similar temperature:
Here is a slip with Unitronic Stage 1 91 tune. You can compare to the 594' marker as the car always went into limp mode at that point. Note the much better 60' time with Unitronic. This, I am sure, is due to the poor track conditions this year. By 330' the Eurodyne has caught up and edged it and by 594' Eurodyne had a clear advantage, even with the weaker 60' time.
