Can anybody help decipher this "manual" I received from the seller of the Euro switch I purchased particularly the "Width Lamp Sensitivity" and the "Low beam sensitivity". I'm guessing the low beam sensitivity is set to the point at which you want your low beams to turn on the and width lamp sensitivity is how sensitive it is? If so, then why could I not set the width lamp sensitivity in bright conditions?
https://drive.google.com/open?id=1dAfeL3iUt12yYcvHcZkz3aya64qJOsAZLoC6a9Bw_qM
Figure 1: Mode switching---- Which modes are there?
1. Tunnel mode (Reaction time:1s) Indicator Light Flash once
2. Normal mode (Reaction time:3s) Flash twice
3. Delay mode (Reaction time:5s) Flash three times
Figure 2: Auto fog lamp setting--->What does it do?2,The front fog lamp does not turn on automatically with the low beam (Flash twice)
1,The front fog lights are automatically turned on with the beam (Flash once)
Figure 3:Width Lamp sensitivity---> sensitivity when you drive into tunnel? how can you put high or low sensitive?
1,Set the current brightness to indicate the wide lamp sensitivity (Flash twice)
2,The current brightness is too bright and the setting fails (Does not flash)
Figure 4: same questions as 3
1,Set the current brightness to indicate the low beam sensitivity (Flash three times)
Figure 5: AUTO file Turn on off/front fog lamp manually---what does it do?
you can turn on/off front fog lamp manually according to the operation of figure 5.
Figure 6:AUTO file Turn on off/rear fog lamp manually---what does it do?
you can turn on/off rear fog lamp manually according to the operation of figure 6.
