This is likely your problem. I’ve seen many issues with these piggy backs. They make for very erratic sensor signals and can do a lot of bad things. Since you have the AccessPort, why not run a real tune?
I verified with Patrick at EQT who verified with you prior to purchasing an Accessport and the EQT dsg tune that it would work fine with a JB4. I believe it has nothing to do with the JB1, other than the higher than stock torque, but it has everything to do with the high 2300-2400 rpm relative to my 20-25ish mph in my neighborhood. It’s just too much rpm and too much torque at that low cruising speed in a residential setting. Just to jumpy/torquey. Other scenarios around town are fine with the EQT file. I bought the Stratified dsg tune last week and couldn’t be happier with the Stratified file for my driving conditions and expectations. It’s much more intuitive and less black and white (minimum 2500 rpm upshift point no matter the throttle position).
Do you experience the same thing without the JB1 (or when JB1 is a pass-through)? The JB4 made a few improvements via firmware updates to smooth out part-throttle feel, so idk how the older JB1 would be.
Even with the JB4, there are still people who say it's not smooth on part throttle.
Not bashing the JB piggybacks at all, btw. I happily ran a JB4 for 16k miles before ordering my ECU tune from Ed.
Sent from my SM-G930T using Tapatalk
Paid close attention to my DSG tune on my way to work today. There were streets that allowed me to stay in 2nd gear in the 2300-2500rpm range both in D and manual modes. No jerkiness with part throttle input.
I'd really have to believe the jerky feeling is due to the JB1.
Maybe jerky is not the best way for me to describe it. It is just a lot of torque at a low speed and low gear. Any change in throttle position makes a more than necessary change in speed in that scenario. It was just that D2 was unnecessary to keep a constant 2400 rpm in that one specific driving situation. I have no problem in D3 at the same speed D3 is at 1500 RPM instead of 2400. It is just hard to maintain near-1500 in D3 with the EQT shiftpoint being 1500. I'll try to pay attention next time I take the JB1 off, but I don't remember any significant throttle sensitivity change when I installed it.
I kept the JB1 and didn't flash the ECU because my dealer assures me that even if I tune the TCU, they wouldn't deny a warranty claim if they don't see any history of really high boost levels, which are masked when using a JB1. I don't know if that will actually be true, but that's what my service adviser assures me. I don't have access to a tune shop, so flashing the TCU at home was my only option. I bought a used Accessport and added dsg tunes with the hopes I could resell when I'm finished at a later date.
Next time I go in for service and remove the JB1, I'll see if I still notice any driveability issues in that 20-25 mph scenario.
Has anyone ran FFL-3, FFL-4, or Motul Multi DCTF fluid in their DSG? Just wondering because those fluids are used in cars with more power going through the DSG, like the S5 3.0 SC. Not sure if they would be beneficial once you start adding power / tuning the DSG or not.
How’s the dsg revision testing coming along?I have a new revision that is currently being tested by a handful of customers. Feedback has been positive, but I think I'll be doing another small revision for them to test before finally releasing it.
The new version shifts at lower RPM's at low throttle input, but doesn't take as much throttle to hold gears longer. This seems to address most of the requests I've received so far.
Thanks
-- Ed
Going well... so far feedback has been very positive. Just waiting on responses from a couple more testers before I finally release it as a V2.0 file
-- Ed
Any update on a release date for dsg V2.0?Going well... so far feedback has been very positive. Just waiting on responses from a couple more testers before I finally release it as a V2.0 file
-- Ed
