joseph201185
- New Jersey
- gti mk7
I recently just bought a turbo off ecs for my gti, 3 weeks later now the turbo is smoking. Did any one experience any issues with their turbo ? Or had the same issue
Installed it in a shop and i am tuned and united motorsportsCurrent Mods? Did you or a shop install the turbo? Are you tuned, and which tune?
I didYou did the UM IS38 flash then, or are you still running your original UM toon and just played with the boost settings via the flash cable?
Have you gone back to the installing shop to have them double check their work?
They just said the turbo is bad and it needs to be replaced, its leaking oil into the exhaust but from the inside the turboWhat did the shop say? Did they locate a source?
How though? What is causing the leak.. that's some "we don't want to deal with it" info if I've ever seen any.They just said the turbo is bad and it needs to be replaced, its leaking oil into the exhaust but from the inside the turbo
yes IHIIs IHI like OE or something?
The IHI on ECS is a refurb I believe:
This turbocharger was built by IHI Turbo and is the perfect stock replacement. Some foreign made turbos come with absolutely no warranty and can be hazardous to your car if installed. This stock replacement was made for worn out or broken turbos and designed to the exact specifications of your old unit.
Replace your turbo to restore lost power and regain boost. Be sure that you have everything that you need to reinstall including coolant and oil line gaskets, banjo bolts, and crush washers.
https://www.ecstuning.com/b-ihi-turbo-parts/is38-turbocharger/06k145722h~iha/
