s7wag
- Bedfordshire, UK
ALL SORTED - NEW 5F CONTROLLER FITTED UNDER WARRANTY @ £3018 - GLAD IT WASN'T OUT OF WARRANTY!!!
I've seen a few threads with issues during the cold weather and weird Sat Nav positions...has anyone had the Media system completely go dead?
When i first picked car up system appeared to re-boot a couple of times on the way home. Found 4 errors that were cleared and all seemed fine until yesterday when system turned off leaving speakers making an aweful tapping noise for around 10 seconds until silence. System is now dead and heading for dealer next week.
VCDS showed these 4 faults again - same as first time..
Address 17: Instruments (J285)
3 Faults Found:
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - Intermittent -
16777020 - Function Restricted due to Interrupted Communications
16777022 - Function Restricted due to Interrupted Communications
Address 19: CAN Gateway (J533) Labels: Redir Fail!
1 Fault Found:
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
Intermittent -
3 Faults Found:
1 Fault Found:
Intermittent -
