exhaust venturis are a proven solutionJust vent straight onto the ground
I don't know if most of those systems work the way ours does, in stock form. In any case, I appreciate the pictures even though you can only see so much.It’s a “standard” setup you’d see on Honda evos Nissans ect. I’m at about 680 to the tire, second built motor with crank walk so I’m disambeling and doing a different motor because I want to stay manual.
Possibly volume. Depends how the can is being implemented. Could be oil sump or a pressure equalizer of sorts. It is a bit far fetched from what others have done, but this setup isn't the average either.This is just a question... why so big? what's the benefit of something that takes up a 1/3 of your engine bay? empty it every 5 years?
I haven't heard of these, sounds interesting.They have those $10 upgrades to the stock PCV valve, with a stiffer spring, on Ali Express. Might be worth a try?
