Hello,
I'm on a built motor with EQT XL turbo, boosting 32psi and my engine has some blowby issue most probably due to excess ring gap or another reason.
The OEM PCV valve works good when it works, minimum oil consumption, no rough idle etc. however even the latest version of this valve only lasted 6 months on my engine and I had to put an APR catch can system on the engine. Catch can itself works, it keeps the water vapor and all that other nasty stuff in and no actual oil goes in to the can however my engine started leaking oil from the front timing cover and I am assuming this is due to the fact that APR system cannot release the crankcase pressure correctly like the factory OEM PCV.
Has anyone else seen the same issue? I even tried to vent to atmosphere with the APR can but no difference.
