Ok, I thought I'd start a thread up that focusses on this particular common problem with the Mk7.
So common in fact that VW have acknowledged that this noise can be generated on any and all Mk7 golf, and that it is in fact "normal".
I'd like you guys to be the judge of that, so here's a crappy recording to get the thread started.
http://images.mdr.me.uk/images/creak-edit.mp3
This noise occurs most frequently when you take the car over a long, slow speed ramp at 15-20 mph with your foot very gently brushing the brake pedal (i.e. putting a bit of fore/aft load on the wishbone), but it can happen on any occasion when the front suspension has to flex away from its default centre position and back, such as: on/off the drive; going round a corner and experiencing body roll; braking in reverse on the level; going slowly across very uneven ground; accelerating over uneven surfaces.. the dealer has confirmed that it happens even when the ARB is not connected so it's not the ARB mounts, and the struts and top mounts were replaced, but this did not alter the sound at all.
My dealer initially offered the "solution" to be greasing the wishbone bush. Which they did, twice, and it did indeed quieten down the problem for about six months. But I'm not sure I consider it to be acceptable to require a re-grease of the wishbone bushes every six months in a modern car, and I've *never* experienced a noise like this in any other car in the same circumstances (ok, there was that truck with leaf springs..) so I really don't think it's acceptable.
So, anyone else experienced this noise and asked their dealer about it?
I'd be particularly interested to understand why ours is particularly bad compared to other cars. Not that it helps, as VW UK are unwilling to do anything at all to fix it.
