Code B103E1B fuel gauge not working
Gvazquez
North Carolina
So after installing my pagparts fuel pump recently which by the way is an amazing piece that is working well so far, my fuel gauge is not working. I'm getting to codes in the cluster ecu for both fuel gauge sensor 1 and fuel gauge sensor 2 resistance too high B103E1B. Its an AWD A3 so it has the green basket. I replaced the fuel level sensor just incase I messed it up in the process of installing/removing the fuel pump assembly and still no luck. The connections look good from the level sensor to the hat and from the transfer pump to the hat as well. Has anyone else come across this same issue that has advice?
