artech.dz
- chicago, IL
- GOLF MK7 GTI
hi,
if i have cobb accessport, should i buy obdeleven??
That. Plus if you are going to do any tuning you'll need the Cobb Access Port or other method of tuning in addition to the OBDeleven.Cobb will read the codes and clear them. OBD11 can also read and clear some codes. Cobb cannot change any module parameters like the OBD11 can. They are both useful to have, IMO.
Also, learn to do the adaptations and changes yourself with OBD11 rather than use the built in apps, this way you are aware of exactly what changes are being made.
There's tons of videos on YouTube about the Access Port.hi, is there anyone who has any video or link on YouTube that explains cobb accessport functionality easy way?
Good point. A lot of people think they need to keep the AP plugged in.Also be aware that your AP does not need to be plugged in 24/7 after flashing, so if you need to scan for codes you can simply unplug it from the OBD2 port and plug in your appliance of choice (OBD11, VCDS, etc). I'm flashed with EQT Stage 1 and keep the AP in the glovebox, and have a P3 gauge hooked up for displaying metrics. When changing tunes, be sure you've got your AP plugged into the car directly though, no OBD2 splitters or things of that nature.
