- Phoenix
- 2018 SE DSG
You should regularly use an injector cleaner in the gas but I can't see how your injectors could get clogged so soon. I'm using the original injectors with 130,000 miles and haven't had a clogged injector. I do use a cleaner regularly.Any luck? I'm getting this issue on cyl 1, had all 4 injectors replaced only 7XXX miles ago but i'm worried it somehow clogged again already. Worth trying sea foam or something?
