Mercfh
- United States
So I drive a 2016 1.8T normal Golf. I've been noticing this a lot but have kinda gotten used to it...but it does worry me.
Sometimes at a top (especially on a slight, and especially in the morning after the car has been sitting) when I go from stop to first gear...the car will shudder a bit at a point at letting off the clutch. (it's not slipping, cause im watching the RPM's).
The car has 20k on it, but has done this for basically the entire time as far as I remember. This is my 4th manual car, so it's def. not me just not knowing how to drive a manual.
Some notes:
* It seems to get better as I drive and use the clutch during the day.
* If im able to roll at all downhill even slightly, it doesn't do it.
* Im around 1.5k when shifting usually
* It seems LESS bad the higher the rpm im at when shifting (like closer to 2k)
* Im clutching pretty slowly but it doesn't seem to change it
* Car shifts 100% fine afterwards (As in changing to other gears).
I've heard from someone that it may be from the clutch bouncing off the flywheel just due to low rpm. Hopefully im not causing any damage...I really don't know what the problem could be. The car only shudders for a half a second before it gets into gear. Im 99% sure this isn't slipping due to the low miles and the fact that the rpm's don't shoot up or anything.
Thanks!
Some notes:
Thanks!
