danielmckendry
Is there a way to clean the rust off brake discs? I know its inevitable, they are going to rust but its a bit of an eye sore, everythings sparkly clean, the alloys are gleaming, then you have these discs in behind with spots of rust. When i say clean, i mean an easy way without removing the wheel or lifting the car as i have no way to do either. But there is plenty of room between the wheel spokes to get my hand in and give a good clean if i knew what to use. I think my bilt-hamber spray alloy cleaner has sprayed on them a bit and sped up the process in those sprayed areas
Sent from my GT-I9300 using Tapatalk
