Was at a bit of a loose end today so decided to bleed some new fluid through my PP brakes (even though I only did it last a year ago) and decided to see if there was anything I could do to get a bit firmer pedal.
First of all went for a quick run out to trigger the abs a few times to make sure fluid had moved through there. Then came back and busted out the trusty motive power bleeder 'black label' version (with the screw on Aluminum cap, much more secure ) and put one liter in. I usually go at 15psi but with talk around the forum at the mo pumped it up closer to 30. Bled roughly 200ml through each caliper, no signs of bubbles anywhere (which was to be expected as being a life long biker I'm a bit particular about brake bleeding and as mentioned, only did it last a year ago). I will say that it seems 30psi is better than 15 on these cars.... I have noticed previously when using the lower number you have to crack your bleeder screws more to get the fluid to move and even then the whole process is slower (and maybe, cracking the screws more raises the potential of air around the threads?).
I normally stop there and call it good, but this time, got daughter to press the pedal with the bleeder still attached and went round each caliper again for a confirmatory bleed. Given I was getting a bit low on fluid only did a couple of pedal pumps per caliper.
Just took the car out and had a quick go and I do think the pedal is a little firmer and shorter. Could be just fresh fluid I guess, or maybe the combo of higher pressure and quick confirmatory old style pedal pumps has helped a bit.
