Brad.R
- Austin, TX
- 2018 Golf R
Hey everybody, long time lurker here. Primarily active in various Facebook groups, but the forums are a great resource as well so I figured I'd make a build thread. I don't see a lot of modified 6MT Mk7.5s, so hopefully I can help anyone out with build questions.
Car was purchased new in November 2018. At the time of posting, it's April 2020 and the car has about 21,000 miles on it.
2018 - Lapiz Blue - 6MT - USDM Spec
ENGINE / DRIVETRAIN
Equilibrium Stage 2 Protune, via COBB Accessport - Launch Control, Flat-Foot Shifting Enabled
NGK Racing Heat Range 9 Spark Plugs
Integrated Engineering Gen 1 Carbon Fiber Intake + Intake Pipe
APR Turbo Inlet Pipe
Integrated Engineering Intercooler
Integrated Engineering Downpipe
APR Mk7.5 Catback Exhaust with Diamond Black Tips (Latest revision)
APR Pendulum Mount (2nd one, see previous mods)
034 Upper and Lower Dogbone Mount Inserts
Southbend Stage 3 Daily Clutch + SMF
Fluidampr Crank Pulley
ECS Bleeder Valve
ECS SS Clutch Line (Swirl valve NOT bypassed)
Dieselgeek Six Sigma Short Shifter
BFI Stage 1 Engine Mount
BFI Stage 1 Transmission Mount
SUSPENSION / WHEELS
APR Rear Sway Bar
Moog Endlinks
Titan7 TS-5 18 x 8.5 +44 - Machine Black
Titan7 Tall Center Caps - Machine Black
MEVIUS Lug Bolts - Conical - 14 x 1.5
ECS Hub Rings 66.56mm to 57.1mm
Michelin Pilot Sport 4S - 255/35/R18
EXTERIOR
XPEL PPF - Front Bumper, Hood, Mirror Caps, Partial Fender
IGL Ceramic Coating - Paint, Engine Bay, Wheels, Glass, Brake Calipers
Aerofabb V2 Street Splitter
Aerofabb Spoiler Extension
Badgeskins Mk7.5 Headlight Amber Delete
INTERIOR
BFI Black Anodized Aluminum / Alcantara Shift Knob
BMS Clutch Stop
Uniden R3 Radar Detector - Hardwired
BlackVue DR590W Front + Rear Dashcam - Hardwired
DSG ECU Retainer (6MT cars come with a metal cage around the ECU)
Spare Tire Kit
OBDeleven TWEAKS
Windows Up/Down with Keyfob
Dash Background
Reverse Passenger Mirror Dip
Soundaktor Disabled
Rough Road Optimization Off (2018+ do not have Starting Vibration)
Headlight Amber Side LEDs off
Taillight Red Side LEDs off
Linear Pedal Response
UPCOMING MODS / CHANGES
Dieselgeek SuperPin - I currently have this waiting to be installed, but have not found the motivation to tear apart my console for it yet.
EQT Vortex XL with HPFP and LPFP or MPI - These will be the last mods, once all other supporting mods are in place. Unless COBB releases flex fuel support, I plan to run the turbo on pump gas for high 400s whp.
PREVIOUS MODS
aFe High Flow Filter - Removed when I upgraded my intake. It worked fine, but I'm a slut for carbon fiber.
Stock Endlinks - Noisy after RSB install, also ugly plastic
APR Dogbone Insert - Got absolutely wrecked by hard shifts
APR Pendulum Mount - First one got bent from hard shifts. Replaced under warranty and added 034 inserts.
Without further ado...pictures! These are with all the modifications listed.
ENGINE / DRIVETRAIN
ECS Bleeder Valve
SUSPENSION / WHEELS
APR Rear Sway Bar
Moog Endlinks
EXTERIOR
INTERIOR
BMS Clutch Stop
Spare Tire Kit
OBDeleven TWEAKS
Dash Background
Soundaktor Disabled
PREVIOUS MODS
