2019 GTI Rabbit Edition - 8000 miles
Installed a:
CTS Turbo Muffler Delete
IE Turbo Inlet
IE Cold air intake
First time around accidentally left the factory o-ring on turbo where the muffler delete goes on. Had a lot of boost leak.
Took it all apart removed factory o-ring, make sure the smaller inner CTS o-ring was installed (it was).
Still getting a lot of boost leak (almost like its fluttering) noise while accelerating, not making power.
The 2 screw clamps that are on the hose that goes to the turbo muffler, how tight should they be? They are cranked down pretty tight and are seated nice and deep. Also made sure that the 3 allen bolts for the muffler delete are tight.
I did not grease the CTS muffle o-ring much.. just 1 spot with a little engine oil to hold the ring in place.
Does the muffler delete only install one way? It seems it can go in any way you orient it.
What should i be looking for?
Install instructions: https://www.dropbox.com/sh/rytm0gb1...view=CTS+Installation+Guide+-+CTS-HW-0199.pdf
I installed this part - it only came with the muffler, reused the hose and clamps
https://www.ctsturbo.com/product/cts-turbo-muffler-delete/
Installed a:
IE Turbo Inlet
IE Cold air intake
