I haven’t tried any of the other tunes, only the JB4. So far I really love the JB4.
Something to consider, these cars have good torque down low even on a stock tune. It is hard to lay down all the power even in stock form when you are at lower RPMs. With the JB4 you can break down how much torque/boost you want at each (500) RPM. All the way down, I am adding zero boost to the stock mapping under 2500 Rpm, because it is useless, since it will just spin the tires and go nowhere if I floor it. .In other words, you can add power if you please so down low it will be as much boost as you would like.
I also like that with the JB4 you can keep an eye on things by doing driving logs to make sure that everything is safe, and not pulling too much timing or leaning out the fuel ratio too much., and if you decide that it pulls too much or too little in a certain RPM, you can tweak it and make it more linear, Or peaky depending how you like it. Also if the weather changes dramatically, you can adjust for that as well. Unfortunately, to do all that you have to do a lot of reading and learning, I am in the process of learning, but I think I have it figured out mostly, If you are not confident, or willing to take the time/risk, then may be it is better to go with a tune, instead of the JB4.
Overall, I am thrilled with the JB4, and impressed at what it does for the price. I am enjoying mine!
