Bäsemödel
- Lancaster PA
love it... very seriously considering doing to golf badge delete as well...
whats next!?
whats next!?
whats next!?
So just did made a small update to the interior. We now offer an Auto Headlight Upgrade , which is essentially a plug and play light sensor that when used in conjunction with an auto headlight sensor gives you auto headlights.
All you need is this:
and this
Installation is very simple and it goes a little like this:
Stock switch:
Just press in and turn clockwise a few degrees to the parking light setting to release the lock:
You can then remove the switch (Note we have blue wires because we have the APR boost gauge installed)
Press the tab on the connector to release. A bone tool helps but isn't necessary
Next using an interior tool / bone tool pry the access cover off the side of the dash
Cover off
You can now connect the harness from the sensor
Fish the wire back through the opening
Run the sensor up to the corner of the dash and windshield and again using the interior tool carefully press the wire in the crack to secure and hide it.
Work it all the way back to the panel opening
Bundle and zip tie the excess
You can then pop the cover back on. We actually were able to clean it up even more so that no wire was exposed
A look at the sensor from the driver's seat
You can now plug in your new switch
All installed, just turn to 'Auto' and forget it
And a shot of the car just for fun,
How did you black out the grill?? That front looks great! works so well with the R led.
can you share how you added the gti side skirts
Noticed those this time as well... Would love to know the story
nicely build, just want to ask about 1.8TSI turbo size difference with mk7 Gti turbo. Few ppl say size is same only the turbine is different, better to upgrade to IS38
I heard 1.8T turbo is IS12 which is almost same size as IS20, my ques was have you check the size of 1.8T turbo with Gti turbo and it wud be better to upgrade to IS38The IS38 is a larger turbo than the IS20 that comes on the 1.8t.
Sent from my HTC One_M8 dual sim using Tapatalk
