Sorry to bump old thread has anyone changed that aux pump ^?
copying from other thread:
I pulled a p16C700 code in the engine module yesterday just by scanning... no CEL. Its for "Heater Support Pump - locked out" Not a ton of info out there for 2.0Ts on this mostly for TDIs in Europe and a few posts around here without much resolution or help. Its for one of the two auxillary coolant pumps, I assumed it was for the one that helps cool the turbo after shutting the car off. Apparently there's one under the oil filter housing area and one just below the turbo. I got the car up in the air and pulled off the axle heat shield and disconnected the sensor and messed around with clearing the codes and doing the heater support pump output test while connecting and disconnecting it with the ignition on. The old code dissapeared and I got a static one when disconnected so I figured the one below the turbo is my problem one. I then tried tapping on the aux pump with a wrench while running the heater support pump output test and it started working again I could feel it and hear the noise change. Idk why it would have been stuck before. Hopefully that fixes it for now it doesn't look like a fun part to change. Im guessing passenger axle will have to come out.
