funvw5
- Peoria, IL
Coded my 2015 PP GTI to auto close the windows when it rains. Trying to test by pouring a cup of water on the top of the windscreen. But the windows arent closing? Coded as follows from the following links...
Will a cup a water activate the auto closing function on the windows?
6. Automatic rain closing
Go into [09] Central Electronics
Go into Secuity Access and enter 31347
Go to adaptation channels and set the following:
- (15) Access Control 2 - Regenschliessen_ein aus (Rain Closing on / off) - Select Active
- (16) Access Control 2 - Regenschliessen_art (Rain closing Type) set to Permanent
- (28) Access Control 2 - Menuesteuerung Regenschliessen (Menu Control Rain close) – Set to Active (enables the menu in the ifotainment screen)
9 Central Electronics
Rain and light sensor
Byte 0…Enable Bit 2 “Regenschliessen aktiv”. (rain closing active)
Bit 1 should be active too….Regenlicht aktiv (rain light active)
My Old coding…..00A8DD
My New coding….06A8DD
I changed the code to match the last line here, this was the last thng i did.
https://sites.google.com/a/naturalnetworks.ca/vw-golf-mk7-vcds-how-to/comfort/auto-rain-closing
http://www.golfmk7.com/forums/showthread.php?t=2491
Maybe my test is flawed?
