Nevo
- North London
Has anyone had this offered and had it applied. My dealer is offering as part of a protection pack and wondered what the final result is like?
Waste of time and will likely cause more damage. Go to a pro detailer and get a proper job done for less money.
Mark, I'm interested when you say " likely cause more damage", could you expand on what that damage would or could be?
Sent from my iPad using Tapatalk HD
Sealant systems need to be applied to perfectly clean paint. New cars (in particular those that have been rail transported) invariably have contaminates bonded to the paint which take time and specialist material to remove - this is rarely carried out in the 45 minutes or so dealers allocate to applying Lifeshine so in effect the contaminates are sealed in. Polishing and applying the sealant to less then perfectly clean surfaces generally results in swirling, made more likely by the often less than perfectly clean application cloths used.Mark, I'm interested when you say " likely cause more damage", could you expand on what that damage would or could be?
