AlienSP
- Austin, TX
I have the non-squeezy breather fitting and installed the APR TIP shortly after you started this thread. I used a small screwdriver (<1/8" tip) as a pick to get between the fitting and stock TIP. It came off with a gentle twist and pull. Without the screwdriver, it's held on with incredible locking strength. The APR does have a defined edge to keep the breather hose on, as I can see where this could be an issue to remove again. In hindsight, I should have thrown a caliper on the APR outside diameter and compare with stock OD. Thanks for the warning Demi, it made me think about my method of stock removal and potential problems down the road on the APR.
