bobloblawGTI
- DC
- 19 GTI SE 6MT
Door jam says 39psi, consensus is run 37 for comfort?
I think people are over simplifying things here.Door jam says 39psi, consensus is run 37 for comfort?
You're totally correct. Also important to keep in mind the gti and r are like 61% weight up front...We are far from being anywhere near the load index rating limits... the 19in sizing (235/35) have a load rating of 91, at 36psi they are rated for 1,356lb per corner (over 5,400lb.... the GTIs are ~3.1k lbs, the Rs ~3.4k)
I would not go below 37 psi because of uneven wear however, I ran my old tires too low it seems, usually 34-36 and by the end, I had ~2-2.5mm in the shoulders but the central grooves where ~3.5-4mm...
Like I mentioned above, turns out they where super harsh riding... my new tires are way way softer riding, I can fill them up to 39psi no problem.
(Note the R's OE alignment has a bit more camber up front, but I doubt it makes much difference.... also 95% of the time its just me in the car, never take a lot of weight.)
