WhiteTDI
- Salt Lake City, UT
can the cowling be re-installed with either the EuroCode or EuroSport bars? it's hard to tell if either sits low enough beneath the cowl.
Eurosport fits under the rain tray, you don't even have to remove it to installcan the cowling be re-installed with either the EuroCode or EuroSport bars? it's hard to tell if either sits low enough beneath the cowl.
The Euro Code bar also fits under the rain tray.can the cowling be re-installed with either the EuroCode or EuroSport bars? it's hard to tell if either sits low enough beneath the cowl.
That I need new tiresWhat’s your driving impression?
hey not dumb, I had to take the wipers off, im on coilovers and studs so i needed long sockets in there and that wouldn't fit under the rain tray. Im sure people on normal bolts don't need to take it off just loosen it. to each their ownI installed it. It's great.
Heres my notes
- easy ass install. Took 15 minutes and only because my passenger strut tower was not aligned to the holes well.
- dont remove the wipers... I dont know who did that but it's dumb. You just follow their instructions you dont need extra access to the space.
- if your strut tower holes are misaligned like mine you need the jack up that side of the car to reposition them. Use a Phillips screwdriver down the hole to pry back into place.
- I replaced all screws with the provided non stretch hardware and torqued to 22ftlb. Seems good
Same with the adjustability aspect, that’s a Gimmick for the most part... once you bolt it down it’s doesn’t know the difference of 39.2” vs 39.8” , it’s a not true item that creates a “pre-load”There's no way the 3rd bolt makes a difference
Well, mine arrived today and I'll probably head over to the garage to install it now. Won't test until some time next week most likely.
Nice. Did you order from Eurosport direct? I ordered from ECS because although Eurosport was cheaper for the actual bar they charge shipping where ECS does not, so ECS was still cheaper.. Downside is ECS is still waiting for stock. Currently a 12/9 arrival date at ECS.
