I appreciate the input. I was pretty set on going the APR+ route but I'll look into the options as well. I'm the original owner of my GTI and it's paid for. It's a manual with the performance package. The clutch seems to be holding up well. The only mod I've done is installing some lighter Neuspeed wheels. Do you get smaller gains from stage 1 tunes when you already have the performance package bump in hp and torque?
I have a EQT Stage 1 and stock clutch. I autocross and track the car with no issues. I don't hard launch the car, flat foot shift, and use full throttle in 5th or 6th gear. If you do those things, stock clutch is fine. If you abuse the car, you'll need a new clutch with a true stg 1 tune.
You get the same peak hp with stg 1 tune with any IS20 factory GTI. You don't get a higher hp peak if you're car started as 210, 220, 228, 242hp.
