My alarm is randomly going off.
Started one day, kept happening over the course of a few hours, then stopped after a quick drive to check my battery at a local garage. Chalked it up to a one off, but then it happened again the following night multiple times.
Read a lot about door and hatch latches, lights, internal monitoring, and no amount of messing around helped. Can’t seem to work out a pattern to it either. Perhaps coincidence, but I had to have my heated screen replaced 10 days prior after a chip, so I thought something with the wiring on that, or perhaps a leak bridging a connection somewhere might have caused it.
VW think it’s the alarm siren battery through their fault finder, £500 to replace the unit. Cars approaching 4 years old, I’ve owned it for 1.5.
My question is, is it a common issue on Golfs? I would have expected the battery to last longer than 4 years if it’s a sealed unit!
Is their fault finder reliable enough, or is it just an indication?
Probably over thinking it, but the way my luck is going at the moment I’ll pay to replace it and it’ll keep happening. Do dealers usually charge for additional work if you pay for work that doesn’t resolve the issue?
