Stock up front, Moogs in the rear. 26mm H&R bars F+R.
Only reason to bother with aftermarket end links the PITA that they are is if you have coilovers and are corner balancing the car (otherwise it's impossible to corner balance without the sway bars binding up badly).
Technically you can use adjustables even on stock style springs/shocks/etc but IMO it's not enough to matter.
The car gets beaten on more than most. I consider myself a decent driver but even I wouldn't be able to notice a tiny bit of bind that might be present on shocks/springs. When you corner balance a car on coilovers - it's far more noticeable.
Personally I hate aftermarket end links. They're all bulky garbage and usually with poor anodizing and coatings on the hardware that looks like crap after a year or two. I had Whiteline end links on a prior car and was not impressed.
Most people screw up end link install by not making sure the top and bottom joints are tightened while rocked in the same direction with the wheels straight. Otherwise you'll run into an issue where turning the wheel full left or full right will loosen the end link joint from the "rod" portion of it. This is an install error, and SHOULDN'T be a problem if you pay attention when putting them in. But either way, OEM end links don't unthread at one end in relation to the other.
