904MK7's self tuned build.
904mk7
Jax
17 PP GTI
No im saying make your first column 0 and second 815. Now you can fine tune with the entire right side. Make every column like 400 more than the last at lower boost then narrow it up top. 800, 1200, 1600, 2000, 2500, 2900, 3000, 3,100, 3,200. Something like that.
Ahh, I get it. Thanks! I'll try it!
904mk7
Jax
17 PP GTI
Took the mighty diggs advice and changed the axis. Lets see how this does.
904mk7
Jax
17 PP GTI
I changed the top to start 400 up to 3200. It looks crazy, but I have wastegate opening at 2700 boost pressure at 4k
904mk7
Jax
17 PP GTI
what happened to all this? You still need to recreate it. Take 3000 rpm for example. Now it is all 0s??
I was setting it based on when my request was starting to go up. Made some adjustments. I'll see how it spools today. Thank you!
904mk7
Jax
17 PP GTI
Of course I fix my wastegate issue and my tablet died. Good thing it didn't die while flashing and I had everything backed up, so all is well. New laptop coming today. Hopefully I'll get some logs tomorrow morning. From 40mph in 3rd boost seems to peak at 4400.
904mk7
Jax
17 PP GTI
Well, I'm an idiot, but this week was a good week car wise. I finally fixed my gas tank issue and realized I was reworking my wastegate map backwards. I didn't realize that -0.0001 meant 0% boost. I thought it mean wastegate is closed. 🤦 I would plug in numbers like .25 and .45 which I thought meant wastegate opening 20% no... It means 80% of the airflow is diverted through the wastegate, so no boost. Either way it spools quick AF now.
904mk7
Jax
17 PP GTI
Finally got the car dialed in, but heat and humidity have set in here in Florida. 😭 When I got my 10.01 is was 62* with almost no humidity. Now it's 77* outside in the mornings with 85% humidity.
These two runs were two separate wastegate changes. Only difference was one was uphill and one was slightly down. Ran identical times though. I'm happy with that. None of my runs have been with brake boosting btw. They have all been foot to the floor in 3rd at 50mph.
904mk7
Jax
17 PP GTI
I just compared my fastest run to my run now. In the same temps I'd hit mid 9's no prob. Heat and humidity killed the recent run top end. Thanks to everyone that helped @Diggs24 @arob157
