Before I went to the ps4s I did have the extreme contact for a time and they rubbed too it’s a very slight rub on the fuel filler neck just kinda made the neck shiny but I ended up getting 10mm spacers just for a peace of mind.Thanks for the response!
I was planning on using conti extremecontact. would feel better knowing for certain on fuel neck etc on R.
Was considering putting 245/40/18 tires on 18x8.5 +45mm wheels, on my 2019
Golf R (with stock suspension).
Does anyone have experience with this size tire to know if tire rub/contact with R frame is a possibility going over bumps?
thanks!
It’s likely you’ll be fine, that’s really not that aggressive of a setup.Hi. thanks for your reply!!
Im thinking that if i went narrower (235/40/18), that I can avoid that fender screw removal. The oem tire (235/35/19) diameter is .08 inches BIGGER than that.
Would you agree that would avoid fender screw?
Welcome to the forum. Can't speak on whether or not that tire will work for you but I can speak on the screw mod. It takes all of 5 minutes. You don't need to jack up the car. Only turn the wheels out of the way while doing it. You got this!Hi. thanks for your reply!!
ha. thanks. I saw the removal on youtube.Welcome to the forum. Can't speak on whether or not that tire will work for you but I can speak on the screw mod. It takes all of 5 minutes. You don't need to jack up the car. Only turn the wheels out of the way while doing it. You got this!
You'll be fine. I moved to 18x8.5 ET 45 with 245/40/18 PS4S tires this summer and no issues on stock suspension. I'm even planning on installing Bilstein B6 DCC with Eibach Pro springs and don't expect any real issues with that mild drop as well.Was considering putting 245/40/18 tires on 18x8.5 +45mm wheels, on my 2019
thanks!
My race tires are 255/40/18, same wheel size and offset, and I have no issues anywhere after the screw-mod.You'll be fine. I moved to 18x8.5 ET 45 with 245/40/18 PS4S tires this summer and no issues on stock suspension. I'm even planning on installing Bilstein B6 DCC with Eibach Pro springs and don't expect any real issues with that mild drop as well.
hey. thanks for the info!You'll be fine. I moved to 18x8.5 ET 45 with 245/40/18 PS4S tires this summer and no issues on stock suspension. I'm even planning on installing Bilstein B6 DCC with Eibach Pro springs and don't expect any real issues with that mild drop as well.
