A lot of work got done today. I got up this morning and decided I would going to fix whatever was rattling in front suspension on the driver's side. When I popped the little black cover off the strut tower I saw glitter... not a good sign. I checked and the 3 bolts and nut on the strut were still torqued properly.
After pulling the strut mount and bearing I found the issue. The upper mount was all chewed up where the strut passes through. The strut was obviously moving around, and you can see where the threads on the strut were eating the mounts. It had gotten to the point where the noise wasn't just on bad roads, I would hear things rattle when I was letting the clutch out.
As luck would have it, I had the original upper mounts and a set of strut bearings in the shop. Parts replaced on both sides with OEM, checked multiple times to ensure everything was seated properly, and then confirmed torque. On the test drive the car was silent. Win!
I did find that the shop that installed the clutch did a number on the threads on the driver's side axle. I guess the next time I pull the front suspension apart I will need to replace that.
During that time USPS delivered the last exhaust reducer I needed. Dirty, and powered only by a pot of coffee and a beer for lunch I made my way to the exhaust shop. $140 and 2 hours later I had this.
Yeah it's dirty, today is the first day it hasn't rained in like a week.
There is plenty of room in that b-pipe for a second small muffler if need be.
Home and clean
The catback has 2 lap clamps, 1 at the downpipe, and 1 where the b-pipe meets the muffler, everything else is welded. I had him weld the 3" resonator section to the 2.75" b-pipe. The b-pipe didn't need much work to be a slip fit to the 3" pipe. This should minimize leaks, and make removal easy. The tips ended up like a half inch or so lower than they were, but now I can actually clean them. With the original Invidia setup they were tucked up nicely, but I couldn't get around them to clean them properly.
It looks good, but how does it sound? Way better!
I didn't drive it very far, had the seats down, and all the leftovers in the hatch, so things were rattling around. At idle it is just a tad louder than OEM, under 2500 it seems about as loud as OEM but much deeper in tone, and then at 2800 and up it comes alive.
I have to make a 4 hour drive back home for a memorial this weekend and will get some in cabin video and db with Hz readings.
The 40+ year old me thinks he would like it a little quieter between 2800 and 3000 (after 3k I say let loose the lion), the 30 something year old me would have been very happy with this setup, and the 20 something year old me probably would have wanted it a little louder.
