18x9 +52 Wheel Fitment Question
17lapiz
Ashland, KY
Sorry for the dumb question, but I can’t tell if there is a definitive answer on whether or not these will fit. I have a stock 2017 R. Looking to buy for a winter setup. Thank you!
XM_Rocks
Austin, TX
It will fit but you might need a slight spacer for the rear.
XM_Rocks
Austin, TX
So they’re 18x9 et52 with 245/40r18 winter tires. If I get 8mm spacers for the front and rear I’ll be okay? Sorry for needing clarification!
Every tire is different with respect to tread section width.
Willtheyfit (website mentioned) is a good way to tell.
Input current specs, input new specs, take a ruler on the inside and measure clearance.
The fronts will probably be ok, 3-5MM spacers in the rear is the general consensus.
Why not just buy some Nuespeeds in 18x9 et45? Or if you only want a 245 tire 8.5” is better.
Neuspeeds will be lighter for sure.
17lapiz
Ashland, KY
Local sale has these for $350 with barely used winter tires. I just wanted to make it work.
XM_Rocks
Austin, TX
Buy them then, they’ll work.
Might have to buy some spacers for the rears.
Post up when you get them on.
VOA West
West
I run 18x9 et50, I put spacers in rear.
VOA West
West
What size spacers? Did you have to do the screw mod in the front?
Thank you!
10mm rear
No fender screw mod for front however I’m not aggressively lowered. I have VW driver gear springs
17lapiz
Ashland, KY
10mm rear
Thank you! Last question. What brand spacers did you go with? I see them on ECS tuning and have heard good things about them. Any chance you can prove a link to what I want? Noob here.
VOA West
West
I used 42 Draft Designs, just because I've used them before.
17lapiz
Ashland, KY
I ended up going with 42 draft designs wheel spacers. 5mm front and 10mm rear. It turned out great. No rubbing and the wheels are flush! Thank you everyone for the advice, I’m very satisfied with the results.
XM_Rocks
Austin, TX
They look great! ?
