17" Winter Wheel Offsets
j255c
New York
2018 Golf R Manual
Im going Neuspeed.
777-300ER
St Joesph Mi
Every time I order wheels from tire rack I just order a set of aluminum hubcentric rings on Amazon for ten bucks. Work much better than plastic ones and I've never had a problem with em.
j255c
New York
2018 Golf R Manual
Neuspeed has a sale right now for Black Friday so I went that route. 30-40 more per rim than tirerack options but I know I won’t have an issue.
Clem604
Vancouver BC, Canada
2018 VW GTI
Im going Neuspeed.
Good choice, I have 17x8 RSE05's for my winter setup. The wheels are lightweight, use stock hardware, and easy to clean.
j255c
New York
2018 Golf R Manual
Here’s my winter setup.
Frank416821
Greenfield, MA
This is my setup. I recently went with the recommended oem winter tire size of 205/50/17 instead of the 225/45/17 like my last set. I don’t really notice a change in the way the car handles between the two sizes. I was having major feathering in the rear with the wider tires. Not sure what that was about but had the alignment and struts checked and was told everything looked good. Gonna see how the oem size goes this year.
Dog Dad Wagon
Go Birds
16 Touareg TDI
This is my setup. I recently went with the recommended oem winter tire size of 205/50/17 instead of the 225/45/17 like my last set. I don’t really notice a change in the way the car handles between the two sizes. I was having major feathering in the rear with the wider tires. Not sure what that was about but had the alignment and struts checked and was told everything looked good. Gonna see how the oem size goes this year. View attachment 198100View attachment 198101
what is “feathering in the rear” ?
Frank416821
Greenfield, MA
The rear tires started to feather or wear unevenly on one side of the tire. This is typically an alignment issue but alignment was within spec so not sure what the unusual wear was all about. The only thing I can think of is my commute was mostly on dry highway pavement and I guess that is not great for the wear on a deep snow winter tire.
Maybe feathering was not the best way to describe the wear. They weren't cupped but the tread blocks definitely wore at an angle on the inside of the rear tires.
j255c
New York
2018 Golf R Manual
I’m running 235/45 17s. No issues.
