ktm137
- Yuba City, CA
Hi all,
I picked up a set of 17x8 ET40 Motegi Traklite MR131's over the holidays.
I know they're close on clearing my 2018 SE PP brakes - I need to make sure the tire place is careful with weight placement.
However, I'm trying to decide on tire sizes - options are:
225/45/17 (closest to OEM 225/40/18 OD)
235/45/17 (only slightly taller, but wider)
245/40/17 (widest of course, and shorter OD - slightly better acceleration)
Currently, I'm at stock height, and have the SuperPro camber mounts to install.
Looking at UHP summer tires - knowing that some run wider than others.
I'd like to do the 245/40/17's, but two concerns:
- Rubbing/sticking out of the fender with the ET40 offset.
- Some people have rubbing on the fuel filler pipe with wider tires/lower offset wheels. Is this a concern in this case?
Any experiences/feedback/suggestions are appreciated.
Thanks!
Kevin M. '18 GTI SE 6MT
Thanks!
